I looked on amazon & ebay & 8s monitors are all I can find. Surely there's a 16s monitor somewhere that I can see all 16 cells displayed at once, with bluetooth would be even better.
Thx but no it wouldn't. I'm going to try eliminating bms's & just use just cheaper high capacity balancers & keep the charge volts safely below the max. Then it's easy enough to control the low volt cutoff. So I don't see having a bms as essential & I'm not happy with the limited choices available for 16s bms's & the cost for high amp models is getting ridiculous.
