A typical CC, CV charger will be reducing the amps after the battery gets to full voltage. For example, if 40 amps are going in at 3.55v per cell and the voltage is slowing going up (assume 3.6v per cell charge to voltage) then once the 3.6v level if reached, the amps will be dialed back more and more to prevent the voltage from going over 3.6v per cell. As the battery reaches full charge, the amps should approach zero. Regardless if you started with 20 amps or 40 amps, the behavior would be the same, just over a different time period.
