meltdowndave
Just had new electrical service installed and finished wiring up my 18KPV and two PowerPro batteries. No PV yet attached.
Despite the battery voltages only being 5/100ths apart when first turned on, there seems to be an issue where a low voltage alarm kicks in @ 27% but at 45V. I'm pretty sure that I need to trickle charge each battery individually to top balance them.
My EG4 Chargeverter is connected to a Victron Lynx Distributor that is wired to battery #2 (slave). Batteries #1 and #2 are connected via EG4's parallel cables with battery #1 then being wired to the inverter.
I'm an admittedly lazy person and don't want to physically tear apart the covers on the EG4 conduit boxes and remove cables.
That being said, if I shut down the inverter can I simply open the breaker of the battery that I don't want to charge? If the breaker for battery #2 is open (the one connected to the Lynx/Chargeverter) will it still charge battery #1? Or, do I physically have to remove the cabling of the other battery and connect the charger directly to the battery that needs balanced?
