boondox
Chief Engineer, RedNeckTech Industries
- Mar 1, 2020
- 788
Hi All,
I have a 4S, 1200wH pack of Fortune 100aH aluminum case batteries. A couple of weeks ago a left on load dropped the battery pack to where the BMS shut it off. Oops. I charged it back up and a week or so later I looked at the BMS software (the one in this thread https://diysolarforum.com/threads/f...4-bms-with-low-temp-charging-protection.2884/). The battery voltages which had always been spot on are now pretty far off:
1 - 3.370
2 - 3.338
3- 3.370
4- 3.360
In the "battery view" the column marked "balancing" is blank. The only two parameters I see in the BMS software that relate to balancing are:
Balanced turn on 3.4 volts
Balanced precision .03
Since the batteries are under 3.4V they won't be trying to balance. Should I change that to 3.3v? I'm guessing I need to pull the pack apart and top balance them. As luck would have it I am getting ready to go on a week long trip using the batteries and it would throw a wrench in the works if I need to pull the pack apart and top balance it. Can I get away with doing it when I get back?
Thanks!
1 - 3.370
2 - 3.338
3- 3.370
4- 3.360
Thanks!
