ArthurEld
Solar Wizard
I finished a couple capacity tests using 3.6V top and 2.8V bottom and no absorb.
I got 275Ah on one and 276Ah on the other. That seems about right since I didn't go all the way to the top or bottom and I didn't absorb.
2 more are being tested now.
I tested the internal resistance @ 3.35V, 3.6V and 2.8V. They were all .17 or .18
I can't find anything significantly different about these cells.
So far no clues as to why one cell took off at a little over 3.4V when I was charging in serial.
I'm starting to wonder if the resting voltage was fooling me when I did the original serial run.
Hopefully I won't run out of motivation before I find the answer.
