Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,682
I picked up 24x FullRiver DC250-6 AGM batteries, somewhat used. They had powered a couple Tuk-tuk for tourists. 76 lbs. each, so 1800 lbs.
Most measured 6.26 ~ 6.29V, but a couple were lower, lowest being 6.05V (40% SoC per manual)
I set aside the highest 16 batteries for one 8s2p (or 2p8s) bank. That will supply 2x Sunny Island split phase. The 35 mm^2 cables that came with them should marginally fit the requirement.
The other 8 will supply 3x Sunny Island 3-phase system, will make heavier jumpers for them.
I hooked a 6V trickle charger to the lowest ones for about a week.
I've now paired them up, 2s4p with matched pairs in series, to charge at 12V.
12V automatic charger was too gentle, so now setting up MPPT SCC with adjustable parameters to do 14.8V absorption, 13.7V float.
Outback MX60 with Outback breaker panel, 15A for PV and 63A for battery.
Only one SunPower 327W panel connected for the moment. Voltage too high in series for MX60 (120V limit), will get Y cable and connect two in parallel.
Once all are up to same voltage and SoC, will connect in series for 48V and hook to Sunny Island, which can keep them at float with grid power.
DC250-6 Battery from Fullriver Battery
fullriverbattery.com
