hondaman82
- Jan 13, 2021
- 58
Hi Everyone,
I am building my very first battery pack from 4x280AH LIFEPO4 cells and Daly BMS so I want to make sure no obvious mistake occur. I will need to remove and reconnect the BMS to the cells several times for top balancing series / parallel and other purposed. My question is when remove the BMS, the first step is disconnect the cable sleeve from the main board, then remove the battery connectors. Is there any order of removal? can i remove Negative connector first, then Positve 1, then postive 2... or is it Positive first then negative? thank you !!!!
