What inverter?
1 hr at 3000W for an hour is likely to pop any fuse or breaker sized for 2000W. In your case, I would cable for:
3000W/12V/.85 = 294A (unless they specify 315A in the manual).
Fuse for 1.25X wire rating.
TRIPP-LITE 2000W PowerVerter Plus Industrial-Strength Inverter.
I kind of thought it would have to be fused for 3000W.
Same ones used on local ambulances. It seems work well for them.
Should I fuse for a load of 4000W for 10 seconds? I really don’t think I will run that high of a load but, what if?Fuse to wires not the inverter, no sense having a 200a fuse with 4awg.
Size the wire for the load/inverter and the length of leads.
Your judgment of what I am running on it is not relevant. You don’t know what I am running on it, so there is no way for you to know if there is a better solution. Thank you for your initial response.Are you transporting people to the hospital? If so, the analogy is relevant. If not, there are likely better solutions.
I will have to check specs for wire capacity. Like you said, fuse for wire. Load may have to suffer due to that. I don’t know if ANL fuses would hold the higher amps for a few seconds.Again do you have conductor to support that load?
Seems like 2/0 minimum is needed.
Maybe that's what he has on hand and doesn't have budget for something else? Not sure why you have to bash him about it.Agreed. EXCEPT, that's a pricey unit for what you get, so it's pretty easy to make the claim that there is a better solution.
Again, unless you are operating in the same fashion with the same needs as local ambulances, the above is nonsensical.
