Yea its no Kubota or Bobcat but you can certainly dig a fish pond or some holes for some Leyland's no problem.I get the impression that's it's designed for the homeowner who won't hire a guy to dig a hole.
I think it depends on the soil. High rock or clay content probably a no go.I didn’t realize.
That looks like I could wreck it in an afternoon. Just looks light duty.
Oh yeah, quite aware a person can spend a lot at HF if they want. HF has some solid deals, too. The 2kw inverter genny is one, and a lot of people are running the HF 12k lb winch with zero trouble.Harbor freight has more expensive items:
9 HP Towable Backhoe
Amazing deals on this 9Hp Towable Backhoe at Harbor Freight. Quality tools & low prices.www.harborfreight.com
$3500
There's an 8.5kw Generac for $1200 new in box, a used 8kw DeWalt for $1300, another 8.5kw Generac used 30hrs for $700, a 7.8kw McCulloch for $350, and multiple Onan RV generators in my area. I just wouldn't do a $2000 Harbor Freight generator with these options available. Bigger bang for the buck in the used market.
Been looking at that one, if I didnt have the predator and wasnt moving up to a honda (Im not) that would be my choice.I got a Champion 2500 watt dual fuel inverter generator. I have two 15 amp Schumacher chargers that I can run at the same time....one for each battery bank. On the 15 amp mode they pull less than 200 watts each which means that I can run the generator on eco-mode all day and use very little propane. I have an old school 5000 watt gas generator that will only give me 7 hours on 5 gallons of gas. The little Champion generator only weighs about 45 lbs. It makes more sense to run the little one for small tasks like battery charging or household things.
Harbor freight was on my list, but everything they have is gas powered. I can store propane for years if need be.Been looking at that one, if I didnt have the predator and wasnt moving up to a honda (Im not) that would be my choice.
From reviews on youtube the champion (dont know if its dual fuel but its the 2500) is actually lighter than that at 39 lbs dry, more compact than almost all its competitors, and tested quieter than both honda eu2200 and predator 2000.
All 3 of those are my main priorities in a generator, whether it puts out 1800 or 1900 or 2000 watts running doesnt matter
If I have a dislike maybe its that beautiful shade of "calling all crackheads, steal me!" yellow that shouts across a campground parking lot. I think they used to do it in black but it was the 2000.
Champion is supposed to be a legit company, if this has the reliability to back up its other assets this may be the best choice of all. I see honda as resting on its reputation while sending production to thailand and offering little real innovation, with Harbor Freight holding down the fort being "almost as good as brand A at half the price".
Definitely buy whatever you're comfortable with. I don't mind buying and inspecting used equipment.Im not so sure a genny is something Id want to buy used unless I was really broke or wanted a backup for a more trusted one. You just dont always know its previous history and its anything but idiot proof. Too many people out there lacking common sense about mechanical things, as well as the basic idea, who sells a perfectly good.generator they bought new? If they didnt then they stole it or bought it used themselves, and dont know its history. If I need to count on it in an emergency, would rather not have these lingering questions.
Has anyone here thrown away money on the old stormcat generators from HF? The red 2 stroke one they cloned into the tail gator? I dealt with one of those for exactly 88 days, on the 89th I got all my $89.95 plus tax applied to the then new released predator. I really wanted to like it but it was horrid. Flooded all the time, and I think thats what lead to the very common broken recoil starter. The flooding probably allows greater sealing of the combustion chamber and it yanks the pull cord out of your hand and breaks the plastic pawl. I STILL tried to keep it for awhile, and used my makita drill with socket on the crank bolt. Sounded like a dozen tiny dwarves stuck in the crankcase with hammers pounding their way out. Output was crazy varied random.
Even though I beat it up for 3 months and brought it back broken they cheerily gave me full credit and patted me on the back for one thing... i was one of like 1 guys out of 10 they said that really removed all the fuel.
I saw the manual had a hard on for that so pulled the fuel line off the carb and gas tank and blew compressed air in both directions through the lines. Couldnt even smell gas let alone see any.
Just did initial setup and break in on two of these for work. Went with them because they run propane out of the box, and we were able to get two of them for less than the cost of a single equivalent Honda + aftermarket propane conversion.I got a Champion 2500 watt dual fuel inverter generator. I have two 15 amp Schumacher chargers that I can run at the same time....one for each battery bank. On the 15 amp mode they pull less than 200 watts each which means that I can run the generator on eco-mode all day and use very little propane. I have an old school 5000 watt gas generator that will only give me 7 hours on 5 gallons of gas. The little Champion generator only weighs about 45 lbs. It makes more sense to run the little one for small tasks like battery charging or household things.
For myself I dont think I have the required experience with a wide variety of gennys I assume would be a prerequisite to detecting faults which are often intermittent. Im mechanically inclined and have technical capabilities but would prolly have to see a good one to spot a bad one, and vice versa.Definitely buy whatever you're comfortable with. I don't mind buying and inspecting used equipment.
Don't know about the US but here down under Yamaha inverter generators are available in 1.0, 2.0, 2.2, 2.4, 2.8, 3.0 & 6.3kVA models.Has anyone else noticed the comparable yamaha 2000 virtually disappeared a few years ago except for the motor being used in other branded units? Were there recalls or defects?
Are they comparable to hondas in reliability and performance? In the 2.2 catagory I believe yamaha shifted production to china at the same time honda went to thailand.Don't know about the US but here down under Yamaha inverter generators are available in 1.0, 2.0, 2.2, 2.4, 2.8, 3.0 & 6.3kVA models.
That was the finest and most affordable stump pulling sport cruiser of all time.FJ1100
That would have been a nice ride.I am biased toward yamaha, this was long ago but I owned one of these
A friend had the 850 custom version of that yamaha. No issues.That would have been a nice ride.
In 1984 I rode an already well worn out Yamaha 750 triple cylinder to central Australia on a 10,000km run over 16 days, camping on the side of the road. Considering the number of close calls, crashes and broken stuff which happened along the way, I'm amazed we made it back home. It was one of these:
My ride buddy had a new (at the time) Honda VF750:
I had a ride on it, 235km/h on the Barkly Highway was enough for me. No cattle fences up there.
I’m 56. I have never matured in the area of speed self control.When youre close to age 60 you realize its pretty cool to have all your appendages intact, no facial disfigurations, etc.
I think a bigger benefit would be the ability of running propane as long as tank size allows.
I can understand that. I had a lower leg amputation following a cycling (not motorcycling) accident in 2007. Was doing about 30km/h.When youre close to age 60 you realize its pretty cool to have all your appendages intact
Thats funny (weird not humorous) around 2007 i got the most severe injuries in my life from a bicycle wreck. And I totalled 2 mcs, 2 cars, several other serious wrecks.I can understand that. I had a lower leg amputation following a cycling (not motorcycling) accident in 2007. Was doing about 30km/h.
Nowadays I'll have one beer and I'm legless.
