Checkthisout
Solar Wizard
- Nov 14, 2021
- 4,810
I don't know how it bypasses the low oil switch for starting. I would think that that switch opens (closes?) the circuit and wouldn't allow it to even start.
Depends on the machine. Some just close a switch that grounds the coil.
Honda uses capacitive power to keep the low oil light on for awhile so you can look and see that's the issue.
The ignition coil on the 2000/2200 is also controlled by the inverter. The inverter applies and cuts power to generate the spaek so its not as simple as just grounding it out to stop it.
