Hi everyone!
Damn, it's hot out
I'm currently working through my first summer with 3 x EG4 Wallmount Batteries in parallel with an 18k inverter. The manual does not mention much about recommendations on battery treatment after initial setup. I'm hoping to gain any wisdom that can be offered. The questions that stick out to me are the following, based on my experience with several electric vehicles:
Damn, it's hot out
- Should I be looking to change the default settings for the minimum/maximum state of charge to prolong battery life if that is my goal? For example, it's recommended to keep electric vehicles below 80% and above 20% as a rule of thumb unless the power is needed. So, I would think during the summer you might keep batteries in this zone, as storage really isn't a problem.
- How often should I charge to 100% and discharge to 20% to allow BMS calibration (or other percentages perhaps)? I know this was a big deal in the past for older EVs like the Nissan Leaf; otherwise, the BMS gets out of whack enough to be noticeable.
- Should I be leaving the batteries at 100% SOC for a certain amount of time to help with BMS calibration? Again, this was a thing for older EVs like the Nissan Leaf, but it might not apply here.
- Is there any issue letting the Chargeverter top off the batteries all the way to 100% until the Chargeverter stops pushing power? I have my batteries set up to the inverter without solar panels currently, looking to add those after I sort out a ground mount. I've been topping off the batteries with a generator and EG4 Chargeverter V2. I did this last night, and the Chargeverter ramped itself down and all the batteries went into standby after 10-15 minutes at 100% SOC. Just want to make sure this isn't tough on the batteries.
