Gold plated.$1000 for an enclosure and BMS? How.
Must be.Gold plated.
Bms, case, class t fuse and holder, shunt, switch (60v 200 amp), wire, bench power supply to balance, good clamp multimeter, hydraulic crimper, etc.$1000 for an enclosure and BMS? How.
You can get a Luyuan box and JK BMS which is basically everything you need for well under $1000.Bms, case, class t fuse and holder, shunt, switch, wire, bench power supply to balance, good clamp multimeter, hydraulic crimper, etc.
Case can be expensive if you buy. Diy case with compression adds $'s.
Some of the stuff is one-time (but if you don't have it already...) some you should buy for the powerpro (class t fuse, shunt).
$50 here, $100 there, it can add up.
That makes sense until you factor in being able to buy 2 or 3 all in ones for the price of one setup via components.I have a HAM friend that is advising me to go with Schneider inverters that honestly would be out of my price range. But more back to the topic here, he's now up to 11 batteries of 48v, 200ah each. He sent me to Aliexpress, where I ordered 16 cells and a Daly BMS for $1007. Yes, I'll have to wait two or three months for them to arrive, but $$$. I'll build a rack to suit, but...to the topic, I feel like the advice from another friend is worth taking: don't put all your eggs in one basket. He said it's not exactly wise to buy one inverter/charger/whatever unit to do it all. When one part of that unit fails, you either buy something to pick up that function or you replace the whole thing. And you could've bought individual components to start with and maybe cheaper?? So. I'm learning. Studying. I don't have a lot of money to spend on it, but it's tornado season and it seems that our power coop is targeted by storms these days and my wife was not created to do without power. Not to mention the cost of power is ever increasing. Thanks for the help!
yeah, all that's crossed my mind a couple times. I throw my hands up and yell, "Well, there's ANOTHER option!" It's SO hard to make a decision. Anyway, I feel like I've hijacked this thread.That makes sense until you factor in being able to buy 2 or 3 all in ones for the price of one setup via components.
Plus the all in ones are repairable if you buy the right one. You just replace the bad board if something happens and those boards at least with my tp6048 are WAY cheaper than any of the component setups pieces.
Since you will have spares if you spend the same money you can just swap out a bad all in one and be back up instantly while getting the cheap parts to get the bad all in one back going![]()
Yeah, there comes a point where many cheap things is less expensive than one "Good" one, though everyone gets to make their own choice on each piece. Your HAM friend with his Schneider inverters and AliExpress batteries seems conflicted. 8*)That makes sense until you factor in being able to buy 2 or 3 all in ones for the price of one setup via components.
It's called a 'wide ranging discussion'. 8*)I feel like I've hijacked this thread
Be careful with AliExpress unless you know exactly who you are dealing with.I have a HAM friend that is advising me to go with Schneider inverters that honestly would be out of my price range. But more back to the topic here, he's now up to 11 batteries of 48v, 200ah each. He sent me to Aliexpress, where I ordered 16 cells and a Daly BMS for $1007. Yes, I'll have to wait two or three months for them to arrive, but $$$. I'll build a rack to suit, but...to the topic, I feel like the advice from another friend is worth taking: don't put all your eggs in one basket. He said it's not exactly wise to buy one inverter/charger/whatever unit to do it all. When one part of that unit fails, you either buy something to pick up that function or you replace the whole thing. And you could've bought individual components to start with and maybe cheaper?? So. I'm learning. Studying. I don't have a lot of money to spend on it, but it's tornado season and it seems that our power coop is targeted by storms these days and my wife was not created to do without power. Not to mention the cost of power is ever increasing. Thanks for the help!
With AliExpress you never know exactly who you are dealing with from one day to the next. I mean, I buy $50 depth sensors because they work and I got tired of replacing the $700 ones every few years, but I don't have any great expectations for them. They've lasted a year so far, so I'm pretty happy, and their $3.5 USB-RS485 interfaces seem to work fine, but I wouldn't buy anything that I was going to depend on for safety or continuity of power.Be careful with AliExpress unless you know exactly who you are dealing with.
My question is about all the COMMUNICATION (edited) between chargers, inverters and batteries. What are they saying back and forth that would make me want to spend tons of money on, say, eg4 batteries over just buying cells and a BMS and building a homemade battery?
So, I'm new to this, but plenty experience with electrical. My question is about all the COMMUNICATION (edited) between chargers, inverters and batteries. What are they saying back and forth that would make me want to spend tons of money on, say, eg4 batteries over just buying cells and a BMS and building a homemade battery? I have an older 15kw Winco standby generator that works great, but supposedly it may not put out clean enough power to go directly into an inverter?
It seems there is a "new" chargeverter from EG4, for $79 more than the "old" yellow one, and as of now available for pre-order.
EG4 Chargeverter - GC | 48V 100A Battery Charger 5120W Output | 240/120V Input
Signature Solar provides solar panels, off-grid solar systems, grid-tie, and hybrid systems. Quality solar inverters, bifacial solar panels, complete solar kits, solar batteries. Featuring brands such as EG4 Electronics with their solar battery, LifePower4 and EG4 LLifePower4 and EG4 LLsignaturesolar.com
Does anyone know if there is any difference between this new grey model and the older yellow one that justifies $80 more? It seems the form factor might be different as well?
Edit: It looks like these are the "new" features:
Dry Contacts:
- Control of generator start/stop function based on Voltage or state of charge (SOC)
Using EG4 Batteries?
- Closed loop communication with EG4 batteries for charging based on battery state of charge (SOC), when batteries are not in communication with the inverter
I was wanting to get another yellow one but can't find them on Signature Solar's site anymore. Just this one.
Also new grey chargeverter has softstart/ software current ramp up. The original yellow unit could draw in excess of 150 amps on the dc side as breaker was turned on. Also drew more than 20 amps on ac side on 120 vac input.It seems there is a "new" chargeverter from EG4, for $79 more than the "old" yellow one, and as of now available for pre-order.
Dry Contacts:
I don't think this will be a real issue. Set the voltage to only hit your desired float level and the current will drop off when the battery get's there. It won't "STOP" charging completely, but the current will fall quite low and keep the battery at your float level until you shut it off."If using the Chargeverter when connected to the grid, the charger will not automatically start/stop the charging cycle according to the parameters set by the user."
It's the other way around. I don't want it to turn on the generator if shore power is available. It doesn't make much sense to run the generator if I have shore power available to charge with. If I add a switch on the dry contacts I can easily disable gen-start so it doesn't inadvertently start the generator when on shore. That line in the manual seems to suggest the CV can detect when the input is from the generator or shore and that would be freakin' awesome if it just knew....but I don't know how it could tell the difference.The idea of the Chargeverter with Auto Generator Start/Stop is that it will turn on when the battery gets too low, and shut off when it goes above a set threshold. But from the manual, it says that function does not work when connected to grid power.
If you wanted that automatic function from "Shore Power" or any other grid source, I don't see why this wouldn't work. When the battery goes too low, it will close the gen start relay. That connects grid power to the Chargeverter's input. IT then ramps up and charges the batteries. When the battery reaches the set level, it opens the gen start relay, that disconnects the grid input power from the Chargeverter. In my mind, it seems that simple, it should work just fine.
In my case, I will use it with a generator, but my generator does not have electric start. I will have to manually start it when my battery runs low. But I still think I can repurpose the gen start/stop relay to still shut down my generator once the battery reaches my full threshold level.
