I have a Victron SmartShunt to monitor my solar battery bank in my solar electrical room. The shunt uses bluetooth communication which can be connected to, using a smart phone. The app VictronConnect has all I need to monitor my OFF-GRID system.
The device is great and so is the VictronConnect app from Victron. But the range of the bluetooth is only about 20-30ft, which is pretty lame. I hate going outside several times a day to check on my battery levels, especially in the winter. The electrical room is about 150ft from the house.
Do any of you know of a bluetooth to wifi bridge or gateway that would allow me to access my SmartShunt via wifi. I have no other Victron equipment.
A Cerbo GX would facilitate this if I really wanted to drop $600 total for the Cerbo GX and the Display. I just can't justify it.
Seriously, I need a cheaper solution to just connect to the bluetooth SmartShunt device via wifi.
Solar Electricity Investment.
1840 watts of Solar panels. (2 sets) of 6 panels/100w each, wired 3s2p. (1 set) of 2 panels/320w each, wired 2p.
(3) 100/40 MPPT charge controllers
(8) 100Ah Sealed Lead acid batteries, wired together as 2s4p, 24volt system
(1) 4000 Watt Pure Sinewave Inverter
(1) Victron SmartShunt for monitoring Battery status
(1) 10-circuit manual transfer switch. Connects the solar through an RV 30amp inlet box to the load center. 120v only with solar.
Most of the day the items in the house consume between 500-800 watts. Microwave and coffee pot add another 1500-1800 each. Oregon is NOT known for its sunshine, so, solar energy must be monitored.
