The Watts, Amps & Voltages from the solar array has little to do with the batteries on the other end of it. The Solar Controller (SCC) is what manages & handles that. Most SCC's can do 12/24/48 Volts Batteries but pending on what voltage of battery you have the SCC will have limits as to the Watts, Amps & Volts it requires to deliver the max charging amps it is designed to do.
You are a HAM OP so you should know more than the average person out there as a byproduct of your hobby. I have lived from Coast to Coast and from our most southern tip to the Deep Arctic (Iqaluit Nunavut) and everywhere uses 120/240VAC 60 Hz. I lived in Calgary & Edmonchuck for a few years and am well aware of Alberta Power systems as well.
My "warning" is just a fact of life which applies to all cells regardless of AH Capacity, it is something that needs general understanding and acceptance that many vendors "play numbers games" and sometimes will use ongoing misinterpretations & misunderstands to further their malarchy. Many are quite good at mis-representation and doing it in a way that they get away with it.
Example.
EVE LFP 280K are rated for 6000 Cycles to 80% Gross Capacity, some companies advertise 280AH cells to 10,000 cycles BUT to a 70% Gross Capacity remaining and they hype that their cells are good for 10,000 cycles... The "Industry Standard" is to 80% Gross Capacity remaining...
Many companies sell cells rated at 280AH and state you will get 280AH from those cells. The GOTCHA in this, is they will take B Grade cells and test them from 2.500 to 3.650 using the Gross AH to show that they will deliver that BUT in reality THIS IS FALSE and horribly misleading! A "Proper Grade-A" Cell will come out between 288-295AH Gross AH but 277-282AH Net AH.
All Batteries of ALL Chemistries have TWO Voltage Values.
- The Allowable Voltage Range, which is the voltage range that they can operate WITHIN without hard/damage/degradation. For LFP this is from 2.500-3.650 Volts per cell. The AH from 2.50-3.65 is the GROSS AH Rating and this is NOT what the cells will deliver in reality.
- The Working Voltage Range is from 3.000-3.400 Volts per cell, this is where the NET AH comes from which the cells will actually deliver. This is the primary reason that ALL LFP Nominal Voltages are stated at 3.200Vpc (50% SOC).
** All LFP will "Settle" post charge input, so even if you charge your cells to 3.650 and allow Amps Taken to drop down to 2A and fully saturate the cells, stop charge input and without ANY load at all, the cells will settle and within an hour you'll be seeing 3.500Vpc on average and another hour later they'll be settled to around 3.450Vpc +/- a wee bit.
LFP has an Extremely FLAT voltage curve from 3.000-3.400. Above 3.400 to 3.650 is the sharp cliff climb on the voltage curve and at most 10AH but usually about 5AH
Gross Capacity and the cells will deviate from each other at these voltages as you are exceeding the working range. Below 3.000 is a cliff fall on the voltage curve and again at most represents 10AH but usually about 5AH of
Gross Capacity.
Properly Matched & Batched cells that are Grade-A will deliver that 280AH from the Working Voltage Range of 3.000-3.400.
There is of course a Price Difference that goes with that and 95% of folks don't wanna pay that not realizing the down the road implications.
FYI:
I am 100% Offgriid solar powered up near Algonquin Park Ontario. I run off 24V with 1295AH/33kWh battery bank consisting of
1x 24V/105AH (Matched/Batched Grade-A),
2x24V/174AH (Used EV Grade LFP - Thin Prismatic) &
3x24V/280AH (2 Packs of B-Grade & 1 Pack with Grade-A Matched/Batched)
All managed by JKBMS' with 2A Active Balancing.
You can see more details here:
About My System (updated NOV.2022) which is a tad out of date as I am making changes now and again in spring when I add the next Midnite Solar Classic-150 SCC and it's array of Q-Cell 395's.
Be careful of Wives Tales generated from Misinformation & misunderstandings... There is piles of it out there and most especially on Youtube ! So many "fools" call a Single Battery a "Bank" because it has several "cells" in the battery, but these people also think that a car battery is One Cell when it is not. A Bank is obviously 2 or more battery packs (regardless of the number of cells within each pack) in parallel.
Hope it Helps, Good Luck.
