timselectric
- Feb 5, 2022
- 19,674
Most BMS's have passive balancing.
Be very careful to not let the voltage rise above 3.65. If your bench power supply gets nudged and the voltage setting gets changed your voltage can skyrocket once the batteries reach 3,65. I found out the hard $$$ way.
It's generally recommended to do a paralleled top balance, before you use new cells. The bms will do it, but it's a very long process. Unless you have active balancing.
I will give it to you in per cell voltages so it is universal for everyone regardless of pack size. These numbers are my preferences based on stopping charging to approximately 90% SOC for longer pack life.Charger voltages. What would be the absorption and float volts for Eve 24v battery pack?
Presumably that is the voltage where you want the shunt to reset the Coulomb counter to 100 percent. My inverter automatically does that but my BMS also has a Coulomb counter and if I recall correctly it does have a setting to reset to 100 percent. Of course 100 percent is really only 90 percent and if there is a setting on your shunt for battery size I make that smaller to compensate and give my cushion at the bottom. My inverter automatically connects to the grid at 50 percent and my low voltage disconnect is 40 percent or a voltage that I estimated is approximately that SOC. I trust the Coulomb counter more than voltage if it has reset recently because if it has not reset it can drift and then voltage is a stopgap measure.I have a Victron shunt and I have to set the voltage for when the battery is charged
Yes, exactly. I’m just confused as to what to set the shunt charged setting to, whether it’s the same as the absorbtion or different.Presumably that is the voltage where you want the shunt to reset the Coulomb counter to 100 percent. My inverter automatically does that but my BMS also has a Coulomb counter and if I recall correctly it does have a setting to reset to 100 percent. Of course 100 percent is really only 90 percent and if there is a setting on your shunt for battery size I make that smaller to compensate and give my cushion at the bottom. My inverter automatically connects to the grid at 50 percent and my low voltage disconnect is 40 percent or a voltage that I estimated is approximately that SOC. I trust the Coulomb counter more than voltage if it has reset recently because if it has not reset it can drift and then voltage is a stopgap measure.
I don't know your shunt so I was just guessing. As far as I know the shunt does not control anything but if it is communicating with the inverter or BMS then my assumption could be flawed. Take notes and make observations and that will give you a clue. If you set it lower by 0.1 volt it can't hurt anything.Yes, exactly. I’m just confused as to what to set the shunt charged setting to, whether it’s the same as the absorbtion or different
Sorry to hear that. I started using the desktop charger but calculated it would take about 16 days to charge at such 4 amps. So I have my solar charger charging it. Yesterday was cloudy but it received 4.5kw. So it should be getting there. Once they are fully charged I’ll put them in parallel to top balance. The bms shows they are all very close together in volts. I did have an active balancer but managed to fry it when I was connecting it!
Tiny Movements in volts when charging lithium takes a bit of getting use to when your use to lead acid! Out of interest what do you normally charge up to and discharge to? I’m looking at 90% and 10%
What kind of solar charger do you have? Is it a Victron? What settings do you use for absorption abs float?Ok well you can always take then up close to the top then use your desktop charger for the last part. When connecting things like your active balancer and BMS, connect all your sensor leads before connecting to the device.
On my caravan I go up to 90 - 95% and have it set for down to 10%. I have never been that low but I did forget to turn my inverter off for a couple of weeks and and they went down to 14%.
Contstant Voltage (Absorb) 3.45 volts per cell or 8*3.45 = 27.6 volts
It is not recommended to Float Lithium for a long period but use a setting of 3.3 or 3.2 volts per cell so that the solar keeps them full until the sun goes down if the load in the afternoon is enough to discharge them below the voltage they settle at. Do not Float if using a powered charger that is always on.
I do not go below 3.1 volts per cellDo you discharge to 10%? If so what is that in volts? Thanks.
Change the settings on your BMS and it will rest to that number after a few charge cycles.My cells are at 3.346. But the bms app says it’s at 100%
Do you know this chart to be accurate? I’ve seen different charts with different numbers.
