IF, and I stress ONLY IF you decide to try and use a battery without a BMS... you are far better off tying 8 cells in parallel, then making a single 4 s string out of each bundle of 8 cells linked in parallel...
So, 8P4S config...
This way, more of the cells will be balanced to each other...
HOWEVER...
This is not wise.
The cells are not cheap, and no matter how well top, or bottom balanced, the cells WILL drift in ability to charge, or discharge, and pretty quickly you will find cells below, or above the limits for sustained operation of lithium, and they will either be turned to trash, bulge and fail, or simply quit functioning.
use a BMS... it may not prevent issues from evenly charging or discharging, but it WILL stop damage from the scenario by stopping the charge/discharge function.
