Okay, now that we’ve figured out the real use of the C- charge port when the BMS detects a cell overly discharged and turns off the load but allows the battery to be charged! It brings up another Question... Most of the Separate Port BMS only allow 8 amps of charge current? What happens when My Victron Controller sends 8.1+ amps to the batteries? Does the BMS regulate it down to less than 8.1 amps? ... or does it shut down the charging? ... or does it just burn-up ? the BMS ?
Not sure if I want to test it out....?
I do no think you mean charger do you?The charger should trigger the over-current protection which will open the circuit.
I believe the BMS would fry if it receives more than 8 amps.
The BMS’s “over current protection” as you call it, from my understanding, is based on any of the cells’ voltage exceeding a certain voltage ( detected thru the loom).
If that's the case, how is SCC supposed to power up because C- ain't going to provide any reverse current to do that - Right?
I used a Separate Port BMS for my latest configuration, but I’m wiring it as if it’s a Combined Port BMS so that if the BMS detects low voltage it shuts off the Neg Main current lead but allows the C- Charging port connected to charge the Low Cell! This also allows the Victron battery % charge indication to continue operating properly.
