orangeminnie
- Feb 5, 2020
- 198
I think I've found why the BMV 712's usually don't sync when LiFePo4 batteries are topped off. It appears to be due to very short absorption times needed by these batteries, at least the BB's. Absorption lasts just a couple of minutes (or less), when no loads are present.
Both Victron, Xantrex, and probably other chargers and controllers appear to unconditionally exit absorption and go to float, when the charge current drops to 2A. This overrides whatever fixed absorption time might be programmed. When the programmed surface voltage (typically 14.0 to 14.4) is present, along with a tail current less than the programmed level (typically 4%) for less than the programmed time on the BMV (default is 3 minutes), the BMV won't sync to 100% I have a workaround, but what is everyone else doing?
