heirloom hamlet
life my way
I just got 3 of these with BMS, 3 separate arrays. So far, here are my compaints:i have not but working on wiring up the setup soon maybe in a week or two. i was trying to get pointers from @jasonhc73 to see if i need to keep anything in mind as my setup will be similar but with 2 batteries to start with and 2 more coming in a few weeks.
- My first unit's, first full charge/discharge test gave me 2.2kwh, a very far cry from 5.6kwh it was advertised. I realize that was the battery's original new mark, but they advertised "over 80%". That would be a minimum of 4.5kwh, less than half what was advertised, not even close. Not even sure what to say about that. Another test this week. Then the other two batteries.
- Easy to setup with Anderson connectors, but I have no idea what the BMS I supposedly paid for is doing, for the batteries or for me. Was I supposed to order something else from them that would actually allow me to monitor the batteries/cells?
- I got the AiLi monitor Will reviewed to give me some data at least. But hooking it up when the Anderson plug was used to connect to the battery is a curious thing. I literally have just shoved a little 16awg wire in with the connector for now.
I'm glad I came across this old thread from @jasonhc73 , and am trying to use it to add some insight or direction as I try to use the BYD BMS.
Why didn't I just order the batteries for much less, if the BMS does nothing?
What do I do with batteries that under-perform by more than half?
So far I'm a little frustrated with these things. They work, but miles from what was described and hoped for.
