chaostactics
Im putting in a smart shunt between the battery and lynx and also want to put a ground between the smart shunt and the lynx. Similar to the diagram.
Two issues.
1. The bolt on the smart shunt is too big to go though the bus bar tab on the lynx which means I'd have to bore out the hole on the lynx bus just slightly.
2. The bolt on the smart shunt would be too short to adequately secure the shunt and a lug from a grounding cable.
So can I safely just slightly bore out the bus bar tab and is there any reason I can't just buy a longer terminal bolt to allow me to stack a lug from a grounding cable along with the smart shunt to connect both to the tab on the lynx distributor?
Two issues.
