Hi, all.
My system is going to consist of an 8S x 280ah battery (7.1kwh), a GroWatt All-in-One with the 3000W inverter, and somewhere around 2000W of solar panels with AC backup.
Two questions on calculating amps:
- Should the 24V BMS be rated below, the same as, or higher than the inverter?
- What size fuse / breaker should be immediately off the positive lead of the battery?
I have ideas based on things I have seen, but how do you actually calculate the real values?
Thanks for any and all instruction!
Ron
Ron
