I never see heterogeneous arrays in series discussed. I an upgrading my 23 year old system and would like to retain my old panels, currently configured as three 24V (nominal) arrays in parallel. One array has 10 24V panels (10P, each panel Vmp 34.2V, Imp 3.5A), the other two arrays are each four 12V panels (2s2P, each panel Vmp 17.8V, Imp 7.3A). I'd like to make that all one string with it's own MPPT SCC, separate from a larger second string of new panels. The new battery bank will be 48V, so it would be nice to get the string voltage above that. The easiest way would be to connect the existing arrays in series for nominal 72V. But I never hear of this being done. Is there a problem?
Alternatively I can do it the usual way at 48V nominal with the 24V panels 2s5P and the 12V panels as two 4s arrays, all in parallel. But it would be nice for the MPPT to get the higher voltage/
