JWLV
- May 27, 2020
- 562
I'm about to rewire my array.
I have a EG4 6500EX which can accept up to 500V PV input and has 2 MPPTs.
The distance from the EG4 6500Ex to the panels is about 75 ft.
I have 24 panels. Voc is 39. Imp is 8.5A. These are used/old panels from Satan Solar. I'm seeing roughly 70% output from them. And even less in the summer due to extreme heat >110F. So the Imp current from each panel is closer to 5.5A. I'm in Las Vegas where the low temp might get to 32F once a year.
What I'm thinking:
Choice 1. Two strings. Each string will be 12 panels in series. Total Voc will be 468V. Current will be 8.5A.
Choice 2. Two strings. Each string will be 6S2P. Total Voc on each string will be 234V. Current will be 17A.
Choice 3. You suggest?
What I'm thinking:
