Ok, so for many drop-in batteries, if they claim 100% discharge, I might be able to trust that if I trust the brand. They're likely to have configured their BMS to cut-off at some level their testing indicates I get ~100% of the stated Ah within some margin of error they're willing to stand behind with a warranty.
I'm not looking for "how to best take care of these cells" I'm looking for "if I abuse them a bit should I expect 300 cycles? or 5?"
If I build my own from cells, I guess should be looking at a chart like this
and then defining "abuse them a bit" as 3.0V per cell under 0.25C load.
If I set my BMS or LVC disconnect at 3.0V (roughly 9-10% SOC on that chart). Can someone give me a ballpark on how many cycles I can expect? I know this isn't ideal conditions, but I'm trying to figure out if it is likely to ruin the cells in 10 cycles or not. Assume I store the battery pack inside where it won't hit 80deg and that I charge at no more than 0.5C. For my use case, fast charging isn't needed and 2000-5000 cycles aren't needed.
I understand that finding that exact cut-off voltage depends on the voltage drop based on the current draw, but I know my worst case draw so I could plan and test for that.
At this point, I guess this has become more theoretical than anything. It seems the easiest solution is to size on 80% discharge and buy accordingly. The common less-expensive non-configurable BMS' seem to have much lower points than above, so then I need to decide if I want to monitor that battery and rely on myself to keep it at 80% having the BMS' limit as worst-case backup or if I install a disconnect/protect device and set it where I think the 80% mark is based on testing.
