I see zero issues with that cells that are supported by reasonable arguments. The only potential problem is that we don't know for sure who manufactured that cells.
These cells are showing some pretty promising results. I would not go further in tearing them apart just looking for some issue to justify this as a bad buy. And this is just to be part of the grade A grade B stuff.
@nhanus09, the test you are doing may have some negative impact on the cell performance. I would avoid capacity tests prior to putting the cells under the proper clamping force. Get them in 48V packs, put them to work, and share the capacity results after several charge/discharge cycles of the whole packs.
