I really hate this, I'm so tempted to order these... but with my
I'm using a cheap DL24/P i had laying around. ( https://it.aliexpress.com/item/4000479624068.html ).Cool lmk know how it goes.
What are you using to test..
Yea I'd be curious how these perform under say a 300w load... my tester can only do 144w @ 40a.. The larger test units cost like 2k to pull 100s of watts at low voltages < 5v petty much any cell even junk cells can handle a 40a load ...I'm using a cheap DL24/P i had laying around. ( https://it.aliexpress.com/item/4000479624068.html ).
Sadly even tho is 185w it can only pull 20a. So i'm limited at around 65w. I'll probably just test a couple cells (7 hours charge from 3.29V they where at arrival and about 15 hours to discharge them to 2.55V) before testing the full 24V pack with a 3.5kw inverter.Yea I'd be curious how these perform under say a 300w load... my tester can only do 144w @ 40a.. The larger test units cost like 2k to pull 100s of watts at low voltages < 5v petty much any cell even junk cells can handle a 40a load ...
Both 280 and 302 are manufactured. (Same physical dimensions)does someone have a CATL 302 and can compare it to a CATL 280? Dimensions, weight, and capacity tests.
Some say the CATL 280s are really bad 302, others say no they are indeed 280s.
Weight might be different, but it would be a negligible amount. It's less than an 8% gain.but what about the weight is the 280 lighter than the 302? maybe the are using the same casings as the 302 but have less jelly vs the 280
Correctedso basically no way to tell then 1% is like 55 grams = 1.8 oz
Even if they are 302s testing at 299ah does not constitute very bad.. the 6 iv tested all at 299ahdoes someone have a CATL 302 and can compare it to a CATL 280? Dimensions, weight, and capacity tests.
CATL 280Ah datasheet says the model number is CB310.
The CATL 280Ah cells I got from Docan has scratched out QR code but a portion of it is still readable. It says "CB3100000"
Does this mean it is indeed 280Ah and not downgraded 302s?
spec sheet for CATL 310, 302, 280, 271, 240, 228.do you have a link to the datasheet, which part of it is the CB31, is that the model number of the code of the manufacturer/facility?
Near topspec sheet for CATL 310, 302, 280, 271, 240, 228.
I thought there is no such thing as 310Ah cell
Download - Battery Finds
Get detailed operational instructions, technical specifications on all products using the free specification, datasheet, and user manuals.batteryfinds.com
Sorry I do not understand 'Near top'.Near top
Top of the pdf file page 1spec sheet for CATL 310, 302, 280, 271, 240, 228.
