Alkaline
Solar Wizard
Holly crap man, 299.... I don't think I have ever hear anyone with a 280 cell rating so high. Hey nhanus09 you are 100% you didn't get some CATL 302?
These are certainly 280AH cells. That's what I ordered that's what the label says. Testing cell #2 of 48 now.. maybe a fluk but I doubt it. DOCAN showed me similar numbers of about 50 cells they tested and also a picture of a screen shot printed out from another customer.. see those along with the screen shot and xls data from cell #1 below..Holly crap man, 299.... I don't think I have ever hear anyone with a 280 cell rating so high. Hey nhanus09 you are 100% you didn't get some CATL 302?
That is correctInsane, and you paid $130.00 / pcs shipped for these?
Restricted use regulations: this sample is still in the development stage and can be used for cycle tested under
standard charge and discharge method. Now the cycle number of tests is less than 500 cycles. The cell are only
used for announcements, tests, etc., and are prohibited from being sold to customers.
Here is the spec sheet Docan gave me.. if someone has the QR code parse app and can parse the QR code from cell #1 and #2 below I'd appreciate it or tell me how..The images are from the CATL datasheet. Look at the CB310 model name - there is a chance that these are some early versions of a 310Ah cell.
The cells are explicitly designed for energy storage systems. This is also in the datasheet.
However, the second image shows:
So there are still concerns with cell performance in a few years. I haven't asked for details on that part. It may be an early datasheet that we are getting since it has been created in March 2020 (according to the PDF metadata).
Ty
I'll peel the cover back and see what I findHrm if these are 302 that they are selling as 280 that is not good. But the original QR code is covered up as its supposed to be next to the vent.
No way to tell the 302 dimension wise is the same as the 280?
If they are in fact 302 sold as 280 and they test as they do why would that be a bad thing.. besides not being truthful.. would the longevity be affected..No such thing as a CATL 310, only 302, the 302 will test up to 315.
As far as usable capacity, there is a big difference between a 280 cell testing to 299 vs a 302 testing to 299. Since the original QR code has been scratched off and covered it is going to be a pain to determine what this cell is.
I'll try to look at the dims..Hrm if these are 302 that they are selling as 280 that is not good. But the original QR code is covered up as its supposed to be next to the vent.
That is a good price if you can get 2-5000 cycles from it, if they fall flat capacity wise after 3-500 cycles I’d say that’s not that good of a deal.And despite that - 300Ah for 130USD/cell is a pretty good result. Mine are 135USD/cell including shipping. As said - what matters is the usable capacity we are getting for the money. Based on the first results it looks pretty good.
Right.. unfortunately time is not on our side on testing that.. ill confirm what the warranty they offered was. I think it was 5 yearsThat is a good price if you can get 2-5000 cycles from it, if they fall flat capacity wise after 3-500 cycles I’d say that’s not that good of a deal.
And we will likely not find out anything about that in the next couple of yearsThat is a good price if you can get 2-5000 cycles from it, if they fall flat capacity wise after 3-500 cycles I’d say that’s not that good of a deal.
No and no. Yes I get your point.Does anybody rely on long-term warranty from China? And do you have warranty conditions specified somewhere?
Here are the results of cell #2 . The test cut off a few minutes early due to the time limit I put on the test.. probably would have reached 299 but it stopped at 2.792v.
results: 297AH / 989WH
see files below.
Physical dimensions and weight of 302 and 280 are not the same correct?You either have the best 280s of all time, or you have 302 sold as 280. No way to tell?? without the original qr code.
You either have the best 280s of all time, or you have 302 sold as 280. No way to tellwithout the original qr code.![]()
Yes. That is the $64k question..No but prior expectations was that cells lasted many many cycles, one of the major selling points over AGM/FLA.
I feel it seems many people have noted prior success of LiFePo4 cells of years ago and apply that to what you can buy today. Where as these resellers may take some liberties of our expectations and reality.
Such as living the Wild West of buying cells these days, luck of the draw. Set your expectations low and be amazed if they are exceeded.
