Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
Just to add to the conundrum, different chemistries will drift differently, as will different capacity cells. The larger the capacity the larger potential to drift.... Some BMS' allows you to set the Cell Voltage Difference threshold which can be used to allow for a wider drift while under load to prevent disconnects. Momentary Under/Over voltages should not be a huge issue but if there is a persistent problem, then obviously the Cell(s) will need to be addressed.
Imagine watching a pack built with 1000AH cells, you'd go nuts I think. Hmmm, as if any of us could afford 1000AH cells at $1,100 USD a pop.
Boy would be nice to have 1000 AH packs but 38kgs/83.7 lbs a cell, I wouldn't want to lift them... gosh imagine the shipping costs.... Ahhh to win a Lotto !
Something to note in general. A BMS is not a device which can correct a defective cell, they are quite limited as to what their functions are.
Some links of related interest.
BU-504: How to Verify Sufficient Battery Capacity https://batteryuniversity.com/learn/article/bu_504_how_to_verify_sufficient_battery_capacity
BU-908: Battery Management System (BMS)
BU-1101: Glossary
What causes Lithium-ion to die? https://batteryuniversity.com/learn/article/what_causes_lithium_ion_to_die
BU-908: Battery Management System (BMS) – Battery University
Learn about old and new methods and how innovations may change old habits
BU-1101: Glossary – Battery University
Learn about battery technology, battery maintenance and battery life at Battery University
