I have a 24v 230ah LiFePo4 battery pack made from 8s 3.2v 230ah cells from Docan Technology through Jenny Wu with a JBD 150a BMS. When they arrived a while ago I checked that the voltages of each cell are near identical, and from some suggestions, top balancing isn't necessary if they are new and the same voltages.
However I have a problem when the battery pack is fully charged or near 230ah, two of the cells have much higher voltages than the rest according to the BMS. Below is what I see on the JBD BMS Bluetooth app:
Normal, not fully charged(also very similar voltage difference when charging):
Cells 2 and 4 higher voltage when fully charged:
Does this mean I have top balance all the cells? I had thought that if the cells are tested from the manufacturer, are grade A, and have the same voltages when they receive and test them, then they should be balanced?
