the_uglydog
Hi, I've been having issues with some server rack batteries I bought, 200ah 48v. One of them was working Ok, then all of a sudden it started showing wildly mismatched cells and shut down. BMS is fried. I opened it and tried to disassemble but many of the cells were swollen and showed signs of sparking. When I finally got it apart and tested the cells one read 3.8v and swollen, 3 at 3.2v not swollen, and others at 2.4v and 1.8v and all swollen. only 3 cells are not swollen. I've had another battery that was matched suddenly read 4.0 on one cell and 2.0 on the one next to it. The BMS shut down and shows 0 state of charge but 52.5v for the voltage and when opened I tested and all cells match perfectly at 3.2v, but the BMS showed SCP fault. I've disconnected it from the battery bank, inverter and charge controllers and tried disconnecting the cables and reconnecting them and I also tried to reset it it a few times, it still shows the SCP. I found loose crimps on the BMS to cell leads and loose connections at the cell terminals. I've corrected those but it still shows SCP fault. Could that be a short in the internal wiring somewhere? Would there be a visible burn I could see? Could the other battery have had loose connections as well and that caused it to cook?
