Charge controller to battery to gt inverter
SoilKulcha
I was thinking my array is to big for my inverter . So can I use charge controller(s) . Array to controller(s) to battery bank to 6000tl-x inverter?
Since I am using zero export my inverter will pull power from the battery after the sun goes down until the batteries are depleted. Any ideas are appreciated ?
If you find your system clipping production a lot. Moving some of the panels to a separate SCC is a good solution. Multiple charging sources is perfectly fine. Just be mindful of the battery's max charging current limit.
