This is probably a dumb question, but I spent 10 grand on this large lead acid forklift 1000 amp hour battery, that has no charge rate specifications. The manufacturer the battery simply says get the charge rate off the vehicle it is installed in, obviously it's not installed in a vehicle, anyway 20% I assume is 200 amps, does that seem correct to you? I read that 20% is a good charge rate but I am not sure how amp hours and amps going into the battery relate to each other. It sure seems like a lot of power going into that battery. This forum has helped me a lot, thank you very much for the help.
