Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
Separate Port is supposed to always have the "Charge Port" open unless it is cutoff by the BMS, so that's a simple one.
Seperate Port can also be configured to run from a Common DC-Bus (just clunky) because you have the extra +/- to deal with.
BMS disconnects while charging from an SCC, SCC should immediately jump to standby mode (almost all do, only cheapo's don't). The moment it can send power it will go into charge mode... This is "normal" for a quality SCC. The Solar Panels having to be disconnected from SCC is nonsense UNLESS dealing with cheapo value SCC's. (ie cheap no name brand Chinese / Taiwanese "value" models).
I will answer more "generically" with regards to Common-Port.
When a BMS cuts off for LVD, and it does not go into "Safe Mode" or turns itself off (some do) it should take a sense voltage state reading every few seconds to determine if there is charge voltage available and if so allow charge. With a Relay/Contactor type of system that means closing the relay every few seconds to test for voltage. The FET based BMS' have no relays, they will just open, sense, close if nothing.
This was discussed at Great Lengths previously and boy it even got "warmed up" a bit shall we say. I believe one of the threads even got deleted cause it got nutty.
The real GOTCHA, is there are no "standards" as such and so BMS' vary and there are so many variations and flavours to do all sorts of things. Even things like turning OFF a battery pack and it's BMS as well for a true 100% OFF is not that easy, you'd think it would be ! Almost like a Faceplalm Why the heck didn't you include an OFF Switch on the BMS. Other BMS' can run Heating & Cooling systems and thermal management of the cells and even more.
I hope this answers your Q but I don't think it's the answer you wanted, sorry about that.
To the best of my knowledge, the Chargery will sense the voltage and enable charge. I had two packs in a bank of 4 LVD out, when Genset power came on they took the charge without intervention. I run Common Port.
