couldn’t you have just pulled the one out and tested it on its own?
I had a second 280Ah LiFePO4 set to put online (to later double my battery bank Ahs), while wanting to more fully evaluate my first set of 8 EVE 280 Ah LifePO4s (with have suffered some mishaps). Kind of still going through cycle of wondering if the BMS16T I purchased early 2020, which I firmware updated to 4.05, and then put online with my new unused 24v battery set, might be a bad one. (anyone seen that ???
I think my new LifePO4 set has one battery cell that drains early. ... that likely needs to replaced to get full amp hours out my battery bank (IMO: part of live n learning experiences, on aged order now).
Re My main Chargery BMS Concerns: Here's what is odd to me: My number 7 cell was hitting the 3.65v trigger early at my the higher part of my charge cycles, while the other cells were only about 3.38v. (& Yes, I did previously top balance). Since my #3 cell was showing lowest then, I swapped their positions in my battery bank, to see if the high cell voltage cell would follow my position switch. This is what is
an odd one to figure out: My #3 and #7 cell positions both now appear normal and balanced, but my # 2 cell position now hits the 3.65v trigger way early as my charging approaches full; while my other cells are reading about 3.38v. I am marking my off balance cells voltages histories with sticky tape notes as I try to figure this one out. ... I had to adjust my bulk charging rate down to 27.3v, and my float to 27.0 to continue using my solar system without repeatedly triggering my BMS high cell volt trigger.
While slightly wondering about my stainless steel battery terminal studs compatibility to bus bar and battery terminal materials; I have cleaned all bush bars with slight 320 grit scuffs, alcohol wiped my battery terminals, and put ox-gard on my terminal and bus bar connects. Looking at my clamp on amp meter readings on my BMS wire loom does not make sense to me; as the high volt cell stays high, and amp meter reading do not match my ideas of bringing high cell down in voltage. I do not see a constant amp draw to bring my high cell down down; seen current in both direction while comparing that to the other cells at BMS loom wires. (or maybe I do not fully understand how it all works) ...
Even with newest firmware on both BMS and LCD, ... Maybe I have the roll of dice of a faulty BMS hardware. ... I think my best option now is to test a new BMS8T. Wondering if anyone has a USA shipped option for the Chargery BMS8T 300 amp shunt version (would prefer the newer shunt version). Open to any fix it ideas or further test ideas. ... Rolling w my Learning more all the time program. Previously had my LV2424s user defined Bulk Charge voltage set at 28.0v or 28.2v , ... and my Float voltage at 27.2v ...and saw plenty of previous cycles of balanced cell voltages without this problem. ... Looking forward to seeing balance cell voltage readings again soon.
20 minutes Later
Update: Took a good cell from first battery bank, and at about about same voltage as connected battery bank cells, I switched it with the high volt reading #2 cell: Results: on solar charging: # 2 cell now remains balanced with other cells, but now the #1 cell heads up early towards 3.65v trigger voltage. I think I have a messed up BMS. I have an email in to Jason and Craig asking for paypal options (preferringa USA source option for quicker time response. Might put my older BMS8T back on line, that work fine for so long, that I sparked messing with loom wires without disconnecting ... to test it again. Currently have solar system working on late sun with bulk voltage set at 27.5v and float at 27.0v (kind of low) to keep that high cell volt trigger from cycling.
