Actually they do, you can find how to set them up like this (2 input control signals)
here. EDIT: That's at least for the Multi and Quattro devices, you have to check for other product lines. Also beware, you need to buy a special connecter to connect to the inverter to be able to configure it properly with the Victron Configure software (not accessible via Victron Connect over Bluetooth for this setting).
I did this on my EasySolar, which includes a Multiplus (inverter/charger) and an MPPT all integrated together. So if the discharge contact is opened, the inverter is stopped, and if the charge contact is opened, both the charger and the MPPT are stopped. But you can also do that easily with a charger/inverter and a MPPT that would be separated, using optocouplers.
