eStilo
- May 20, 2021
- 2
Hello, im very green to solar panels and want to charge my ebike battery via solar panels
Im renting a room at the moment so i need portability i want to fit this in my Honda Civic Touring and go camping or trail ridding. Can this system work for me i want to charge straight to the battery (not when ridding) if not what do i need. Ive seen your videos on YouTube and found my way here. I contacted Renogy with this question but no response
48V, 14 Ah (672 Wh) with Lithium NMC Samsung 35E cells, rated for 800 charge cycles
Wall Charger:
100-240V and 50-60Hz input compatible for worldwide use and has a standard North American 3-prong plug.
unsure if i need to use it I would like to just connect solar panels straight to the battery (dc to dc) for charging without inverter.
Thank you, your experience and knowledge will be appreciated
Renogy 200 Watt Off Grid Portable Foldable Solar Panel Suitcase Built-in Kickstand with Waterproof 20A Charger Controller, 200W-Waterproof
Rad Rover 5 battery info:48V, 14 Ah (672 Wh) with Lithium NMC Samsung 35E cells, rated for 800 charge cycles
Wall Charger:
