sunshine_eggo
Happy Breffast!
No. try -2
Ok, Anyway I trust your competence, unfortunately I don't get into my head of this calculation of Mvolts etc. I attach the latest changes I just put into production based on what you wrote to me and I hope I set the battery well. Also yesterday evening due to bad weather I turned off everything except the fv and the battery which had a residue of 14%. Today at 3 pm with a slightly variable day I saw that it accumulated 760 watts, compared to 1,100 previously. I attach the configuration to have your approval! Thank you for all the indications that regardless of the technical side, you were very kind for indicating these parameters to me in such an elementary plant. I also left the float at 13.80 as you wrote to meAnd boost reconnect 13.00 instead of 13.20.No. try -2
Ok, then try to watch this: Only the boost value looks similar.Lesson: I should not post before morning coffee.
I made a math error.
Please change to -4. Everything else is good.
Yes, in fact, I looked. Then I leave all the parameters and then we'll see what happens. Thank you !!!!!That is from a Rolls manual. They are different. Would stick with 14.50.
Hi, I wanted to update you on the latest events based on the parameters you recommended. This morning I left only the battery charged without any load, on the way back I found it in float (16.30 am). It charged only 500 watts versus 1100 charging normally. The parameters are for recapitulating:That is from a Rolls manual. They are different. Would stick with 14.50.
Boost charge 14.50
Float 13,80
Reconnect boost charge 13.00
Time boost 180 mn.
Variation with temperature sensor -4
It seems that despite being very low the battery (1% soc), it had 8 hours to be able to ask the controller for electricity. Today was not very sunny, but I didn't find such a low charge value.
Allora , il soc al mattino era 1% , ho accesso il carico verso le 16 PM e come si vede in tabelle aveva caricato durante il giorno solo 0,51 .1% SoC? Show me the voltage chart
Si probab
Sorry, but unfortunately the translation in Italian creates misunderstandings. I see 0.51, which were absorbed by the battery exactly from 8.00 in the morning to 16.00 in the afternoon with nothing connected, only the panels. In other similar conditions or almost low battery in the morning, I left all the time from 8.00 to 16.00 charging with a total accumulation of 0.92 against 0.51. I don't quite understand these values so low, it seems that the battery after not even half its capacity has decided to stop absorption.
