I shook up the loctite before I used it. Some loctite come up when I screwed in the studs. I wiped it off then let it sit for around 24 hours. Then I wiped off the cells terminals with acetone just to make sure they were clean. I don't see any evidence of any erupting out but I will check under the busbars when I rearrange things.
Yeah mine erupted after using the cells. Definitely check under there the next time you have a chance.
