I have a Mr Coffee 5 cup unit that works great with my 1000 watt MSW inverter. No issues at all.
If you are running it off of batteries, my decion would be based on kWhs per cup. The only thing that would influence that would be inverter capacity.Seems to be the lowest wattage K-Cup brewer
In the winter we keep a pot of water on the wood stove. When there is not a fire going we heat the water on the stove. I guess some folks may drink their coffee cold but I'm not a fan, and you need to have the water at least 180 to get the oil to release from the beans.So, you use cold water?
pressure tank, hand pump and elbow grease.Where do you get the 3000 psi of pressure?
Depending on where your cabin is, that might take you 3 days walking...If you walk to the LCS (Local Coffee Shop) it doesn't require any battery power.
We already have a stove top Coleman coffee maker.Low power coffee maker. Saves a lot of KWh per cup of coffee:
What exactly is a “stovetop coffee maker?”a stove top Coleman coffee maker.
Takes 20+ minutes to make a pot of coffee.
I use a 600W Hamilton Beach every day for five minutes
My stainless steel percolator perks in ?10? minutes.
At 20 minutes coffee is already stale.
That’s similar to the farberware percolator and the really old one I have except mine are 7-cup.
was cuz internet search doesn’t come up with one. Just a percolator.stove top Coleman coffee maker
