Deligreen is closed till Feb.01 due to the holidays.
They will add eh busbars to assemble the cells (extra but like $2 ea or so).
A really great set of reads here:
http://nordkyndesign.com/category/marine-engineering/electrical/lithium-battery-systems/
You'll need to FUSE each pack, I like the MRBF type for ease & simplicity (125% of the output capacity is usual)
Choice of Fuse Sizes Available: 30A, 40A, 50A, 60A, 75A, 80A, 90A, 100A, 125A, 150A, 175A, 200A, 225A, 250A, 300A. Fuse Size List Ignition Protected – Safe for installation aboard gasoline powered boats.
www.ebay.com
Will Prowse has found a lower cost BMS with Cold Temp cutoff for something like $80 but I'm not sure which is which now as there seem to be a couple but they have different software so I'm not sure. There is a couple of threads on it.
Look at Will's videos on assembling a 12V pack, not hard to do, a casing of some sort is not a bad idea, you do not want anything being able to touch the tops of the cells in the pack, not even a stray rodent. A metal box can be used as long as there is a "non-conductive" liner, some folks here found plastic battery boxes for such out of China, quite reasonably priced and some that are way out there in price.
