I'm planning to install several hybrid inverters and connect them to one battery. Each inverter has its own solar array and own AC load. The purpose of the battery is to store excess energy and therefore to share the solar power between inverters (consumers). I've read all discussions here and they all generally support connecting two inverters to one battery. However, the solar systems installers here in the UK refuse to install in such way. They refer to the manufacturers (Sunsynk and Growatt) that do not allow such installation. I need you help to find answers to the following questions:
- Is there any inverters/battery manufacturer that supports connecting several inverters to one battery?
- How can I properly connect the communication cable to BMS? Connecting to one of the inverters? Or through a bus bar?
