"I actually have a 300ah lithium (lifepo4) battery bank. However I am installing radiant heated floors, air conditioning, 12v fridge, water heater, the works "
a 12V 300Ah is about 3000Wh. so you got 3000watts for 1 hours or 300Watts for 10 hours.
but for solar sizing , you need first to consider this battery as a load (since you need to charge it)
Solar is usually available only 5 hours, so your calculation will be 3000W spreaded over 5 hours that is 600Wh.
That is the minimum solar power you need to capture to charge your battery.
since you will probably also use the solar power to fullfill load as much as possible, you need to calculate your load and add those 600Wh.
so let's continue with this AC at 300Wh. for five hours, you got solar panel to produce 300+600=900Wh, so you charge the battery and you run the AC.
when sun goes down, you will to rely only on battery , so the 300Wh for the AC.
with 300Wh for AC on a 3000Wh battery , you can run 3000/300 = 10 hours.
if you need to run it longer, you need more battery and then more solar panels.
if you need to run other loads at the same time, you need at least more solar panels and probably more battery.
in each case, you will need also to increase wire thickness, and inverter power.
since the list of what you want to run seems pretty heavy, i think you can multiply your installation at least by a factor 2.
going 24V would be the easy way.
Also , select devices that are running with "inverters" (now you can find AC and fridge advertised with inverter vs the good old compressor run directly on 110V)
