I don’t live in a cold climate. It’s more of a luxury that will prob be ran 3 hours a day once in a while max. I have a recirculating water system. Same 2 gallons of water being filtered through a 4 step filtration system which includes a30 Sqft, x 12 watts is 360watts draw. Figure 8 hours a day overall, you have 2880Wh just for the floor heat...
Water heat will be in the 1-2000 watt range, a small tank can heat in an hour, then be used for a quick shower, so add in another 1000Wh...
So, 4000Wh daily demand in winter, just for heating and water. /4 less solar in winter... you will need minimum 1000 watts solar input per day... it’s often cloudy in winter, so I would recommend 4 times this much solar...
Just to heat 30sqft in winter with electric radiant...
it can be done, but that is a HUGE awning setup when parked... no way to fit this even on an RV roof...
The Danfoss is rated for the applicationsReplace the compressor with a DC one from Danfoss
Replace the whole system with a 12V DC mini split.
Either option will need deep pockets.![]()
12 Volt DC 6000 BTU Ductless Mini Split
6000 BTU, 12 VDC Mini Split Ductless, Solar Ready Heat PumpAir Conditioner.sharkaire.com
In my field compressors are rated low, medium and high temp... a high temp would be heat pumps and ac, medium would be coolers/refrigerators, and low would be freezers...The Danfoss is rated for the applications
HBP
LBP
MBP
Air conditioning compressors are designated
AC
LBP, MBP and HBP - Meaning and Application Overview - kaeltepartner.fr
Info about the different application areas of compressors.kaeltepartner.fr
Full disclosure: I don't know what I'm talking about.
Idk, floor heat has advantages too... firstly, it doesn’t NEED to heat the air. It sends radiant heat to the body... the room and air can be 45F, and the body can be very comfortable with radiant heat keeping the feet warm, and skin heated from the radiant.The other thing to remember about floor heat is that it doesn't work like any other kind of air heater/furnace.
When you first turn it on, it takes awhile for it to heat the thermal mass of the floor and then radiate that heat to the air around you. I think it would be the absolute poorest way to heat a mobile living space.
First, you must not understand how radiant heat works. I have it in my shop, the concrete mass is heated which then radiates the energy. The "mass" takes time to heat up, you don't turn the system on and think you will have instant heat. The "mass" must be heated at all times.Im only looking to heat a space of 20 - 30 square feet. Since I wouldn’t put the radiant heat under the cabinetry this is totally possible using limited power
Huh, nice story. I guess your brother learned his lesson for the rest of his life. Electrician is not an easy job.Electricity is no joke. I don't think it's safe what you're asking about.
Once my younger brother tried to make some manipulations with our electricity meter to save money. If we only knew what he planned to do we would stop him at once. So my brother provoked a power surge. I'll remember that evening for the rest of my life. Luckily, no one was injured by electricity. We called some qualified guys from https://www.airconservicingsingapore.com/chemical-overhaul/ to resolve the problem with the electricity in our house and to fix our aircon which was actually damaged. I don't know more than how to change a light bulb, so don't ask me why. Now everything's finally calm. And my brother doesn't want to be an electrician anymore.
