Current setup is only for temporary power in case of short outages, looking for more.
Harper1012
Harper, Texas
I have a two hundred amp service, I had my electrician install a 50 amp generator plug RM50P and I have a separate 50 amp generator breaker. I want to build a solar array and use either one or two EG4 all in one power systems with a battery tower, most likely build a separate small building to house to batteries and controller, my main panel is located on the power pole. This is currently a weekend spot but thinking ahead. I have seen the blueprint just seeing the best way to tie it all together. I do want 120/240 setup. Thanks!
