Martin67
Hi everyone got 325 solar on roof of van victron 100-20 four lithium batteries and a Daly BMS 45 12v 100A loaded the Daly BMS tool and it loads up until the log all - scan all page and then you’re supposed to press scan all on the left there is a tick on the USB pic under that two arrows green pointing up and red down under that a pic of a grey battery on the bottom of the page left side it says USB Connected flashing Responding button right SBS Task Scanning and a small bit of green in a long bar that flashes then date-time
It says the port is ok in green pull the USB out it goes red and it just has all the boxes ticked in the scan column
The only thing is that it just won’t go any further page stay like that all the time plus do I plug the Bluetooth into the same hole as the one for the computer the UART PORT
