Hi all... first time caller, long time listener...
I have a solar+battery+inverter setup that primarily powers an off-grid AC dorm fridge at a cabin. The battery & inverter are located in a shed that's a few feet away from the cabin and outhouse (~10 feet or so to each). I'm hooking up a 12v water pump for the bathroom and some 12v DC lighting in the cabin and am a bit bewildered on the best wire choice. Looking for advice on what type of wire is best plus perhaps even a recommendation as to a good retailer to purchase it from.
Since the wire run from the battery would need to go outdoors, I'd prefer something that's direct burial. Low-voltage Landscape wire seems to do the trick here. Is this a good choice? The options I've seen so far don't show any color coding on the wire to indicate positive or negative -- the insulation for both leads is just black rubber. Landscaping wire also doesn't seem to include a ground.
Any advice for a DC wiring newbie?
Thanks in advance.
Thanks in advance.
