Would very much appreciate some feedback as cell and pack voltages seem to drop very quickly, compared to what I'm used to.
Battery / BMS
I have a 560Ah LiFePO4 pack with 8 x (280Ah) cells, pairs of cells wired in series. Yes, I'm monitoring pairs of cells with Chargery BMS vs. individual. I realize not idea. Still, I'm charging / discharging with low C rates. Max is about 150A either direction. Mostly (99% of the time), 40A max from solar or <10A draws from lights, water pump, etc.
I installed this pack in my camper about 18 months ago and have no more than 50 charge / discharge cycles, only 1 hitting LVD (more info below). I have the BMS set conservatively (HVD 3.55V, LVD, 3.0V) and use about 1/4 the capacity in a given day.
My charging settings have been conservative too. I charge to 13.9V w/ 1 hour absorb. I assumed this explained being a bit out of balance. The BMS never triggers.
With 900W solar, I'm usually charged to full end of the day. Evening consumption might hit 100Ah.
Anyhow, last night I top balanced using BMS. See first photo, holding voltage @ 14.1V for 10 hours or so. After cell differential - 11mV.
Then, 20 minutes later, cell and pack voltage with very minimal consumption (-2Ah) substantially down. I didn't unscrew the lid and pull out my fluke, yet, to measure individual cells.
Should be very little voltage sag @ 4A draw. When I first built my pack, after top balancing, I never had wide voltage differentials, especially at the top. (20mV or so max).
A few other data / info points:
The cells are mounted with terminals facing sideways, vs up. I was told by Amy (EVE cells sales) that the orientation was OK. Some on this board said no. I made a judgment call, given low C rates.
A friend recently used it as overflow sleeping at his house and I know triggered the BMS LVD, when the breaker tripped and he ran for several days just on the battery (without solar turned on). I have LVD set for 3.0 / 12.0V.
I had assumed catastrophic failure is the really only failure (IE. completely dead cells). It is possible the BMS draw took cell voltage below or near extreme levels, as I didn't inspect things myself. He charged the batteries back up and put in storage.
Store batteries between 40% and 70% SOC.
I will do a capacity test and see what that yields. And take some more photos today and post as the loads draw the battery down.
Should I prepare for the worst? If this battery has $hit the bed, I don't think I'd do another DIY (this is my third. I built two similar for friends). Just buy server rack and call it a day.
Battery / BMS
