Here's an odd situation that happened today.
I shut down my system (24v- 2kW) so I could remove an unnecessary temperature wire on my two Battleborn "in-series" batteries. Note- I shut down each component using battery switches beginning at the input to the SCC, then shut down the Mulitplus 24-2000 then turned off the battery switch.
Then, I removed the temperature sensor wire from one of the batteries (it's not needed).
Next, reconnected the batteries.....
- Turned the battery switch on.....
- Turned the inverter switch on (not the switch on the multiplus- I have a switch that disconnects the positive cable feeding into the multi....
- Turned all switches "on" (MPPT/PV input)
- Turned on the AC breakers connected to the Multi....
THEN BLAMMO!!!! (sort of)
The Multi switched to CHARGER mode and the BMV-712 said 50A are going into the batteries.
I shut the whole system down again, checked the batteries voltage (more or less 0 volts) so I assume the BMS kicked in and shutdown the batteries.
Next, I put 12v on each (disconnected) battery and put them in series again. Battery voltage went back to a normal 26.5.
Reconnected everything and had no further problems. Multiplus was running fine.
So, here's the question- what caused this and how do I avoid this in the future?
'Glad to be alive....
