curiouscarbon
Science Penguin
- Jun 29, 2020
- 3,024
earth alert!!!!!
you are on earth!!!
you are on earth!!!
Please....This is a serious thread.earth alert!!!!!
you are on earth!!!
Nooooo my potentialPlease....This is a serious thread.
You are grounded!
About time some action is taken to correct this.here is a petition for interested people to sign requesting free access to all Australian standards.
https://www.aph.gov.au/e-petitions/petition/EN4101
Still illegal!!.... Only 12 & 24v systems come under the new lower voltage rules (38v?)It would need some interesting redesign of the home built solar controllers, but it would then effectively become two 50 volt systems.
Even my 12v system contravenes some chapters I have seen because the number of panels exceed the power limitation.
so it seems the lobby from the electricians has won over there.I have read the draft of the new standards. And my understanding of it is, any circuit directly connected to the circuit you wish to work on that is above 60v then makes the whole circuit illegal to work on without electrical licence. It mentions that for instance a charge controller with an input greater than 60v will then mean that the whole circuit then becomes dvc-b and requires an electrician to work on it.
It also means that as soon as you connect an inverter to the circuit, because it has the potential to produce 240v. The whole circuit then becomes dvc-b. So basically you can't run pretty much any panels in series or even use an inverter or it then becomes illegal for you to work on the system without a licence.
And because it's very hard to get any solar Panels that will charge a 48v battery and be below 60v you pretty much can't have 48v battery without an electrical licence either.
So all you can really do is have a 24v battery and charge it from solar panels in parralel. You can't even connect an inverter to it.
I’m glad you aren’t a licensed electrician.I have read the draft of the new standards. And my understanding of it is, any circuit directly connected to the circuit you wish to work on that is above 60v then makes the whole circuit illegal to work on without electrical licence. It mentions that for instance a charge controller with an input greater than 60v will then mean that the whole circuit then becomes dvc-b and requires an electrician to work on it.
Who rattled your chain? My quote was aimed at @dangriffo32, who was providing misleading information. (ie, any inverter connected circuit needs to be installed by a licensed electrician)Never claimed to be a licensed electrician.
Are you ?
