Hi guys. So I get these weird ideas in my head sometimes and this week its a solar boat. Don't ask me why.
My goal is to build a boat that can cruise 3-5mph all day long from sun up to sun down. I've been consider kayaks, canoes, and even paddleboards in this process. This is the current plan:
Get a canoe. one big enough to fit 1 passenger and maybe a few things. Find some sort of leisurely position to sit in it. I'm trying to do this on a budget so no boat as I have nowhere to store it and will need a trailer to pull it. I want to slap it on top of my electric car.
Slap a trolling motor on that bitch. From what I've researched online, these things will draw about 30 Amps or ~400 watts at full power.
It will be a 12V system, simply because I plan to buy a bunch of used shit and 12V is more available.
Steering will be done with some sort of U-joint attached bar and lever system where I can push/pull a bar attached to the motor somehow to turn it. I'm open to other ideas on this one.
Build a solar canopy. Because the sun will power my boat instead of burning my skin and giving me cancer. This will be comprised of 4x100 watt panels from Grape Solar via Home Depot: https://www.homedepot.com/p/Grape-S...ts-and-12-Volt-Systems-GS-Star-100W/204211365 or possibly some used panels I've sourced locally.
I realize these are not 100% efficient so I expect to have some power loss, but I suspect it will be close enough, and if not, I'll investigate what kind of increases I can make in efficiency, or ultimately add another panel if needed. Or I guess I can just slow down...
BUT if you slow down, then pretty much every trolling motor uses a resistor, which is not efficient at all, so I'll have to replace that with this speed controller: https://smile.amazon.com/dp/B01M26Y...olid=35A0SEJSA8TT5&psc=1&ref_=lv_ov_lig_dp_it
I'll be using is with this MPPT charge controller: https://smile.amazon.com/dp/B07B9NF...olid=35A0SEJSA8TT5&psc=1&ref_=lv_ov_lig_dp_it
This propeller supposedly makes the boat go significantly faster, so I assume it probably makes it more efficient, as well: https://smile.amazon.com/dp/B0091VA...olid=35A0SEJSA8TT5&psc=1&ref_=lv_ov_lig_dp_it
Also plan to use it with a standard lead-acid deep cycle battery since I don't really need it to store much energy or last very long. If it shits the bed in a couple years and I've gotten good use out of it, I'll replace it with something better.
Shout out to big Willy, his YT channel is super informative!
I'd appreciate any feedback you guys have on this.
